engine mounts
simpson_eh
engine mounts
Post by simpson_eh »
HI all
popped into toyota to price up front ard rear engine mounts for my rev 3 turbo
t12361-74110 £148.92 +vat t12371-74220 £129.33 + vat. 31st march is shipping time, question is are the uk mounts the same as they have different part numbers ??
cheers
tony
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
tiff_lee
Re: engine mounts
Post by tiff_lee »
What do you mean exactly by UK mounts? the Turbo wasn't sold in the UK so are they NA mounts?
simpson_eh
Re: engine mounts
Meant are the import mounts for a turbo the same as na mounts ??
tiff_lee
Re: engine mounts
Post by tiff_lee »
Given that the part numbers are different I doubt it as they are a different part. Were Turbo mounts not available?
Try pricing parts on here
https://www.amayama.com/en
can be much cheaper than direct from Toyota.
Guy on this thread
http://www.mr2oc.com/62-common-engine-s ... vs-na.html
reckons the NA mounts are all the same as Turbo with exception of the front (firewall?) one
simpson_eh
Re: engine mounts
unfort they dont list this part number, and thanks for the info on bottom link :)
looks like a trip to toyota and a wait for delivery.
dont want extra vibration hence want to stick to oem
thomp1983
Re: engine mounts
Post by thomp1983 »
Why do you think your mounts need replacing are you suffering excess movement?
simpson_eh
Re: engine mounts
Yes knocks like mad under gear change and you can rock the engine a little to easy lol
alanmr2turbo
Re: engine mounts
Post by alanmr2turbo »
Poly bush them and save you £100's
Draven
Re: engine mounts
Post by Draven »
Only thing to take into account with the poly bushes is that they are much stiffer than the standard so this does apply some engine vibration to the cockpit.
Ginjaninja92
Re: engine mounts
Post by Ginjaninja92 »
I went for Powerflex engine mounts, and honestly there may well be slightly more vibration but it certainly isn't noticeable when you're driving.
Considering the price gap surely OEM aren't worth it?
Also there are three different sizes for the front mount (73mm, 79mm, 83.5mm), the rear is the same.
Draven
Re: engine mounts
Post by Draven »
I would say 100% go with the poly mounts, It was more just a fair warning.
