What components are required for complete engine balancing?
Does anyone ever balance the top end as well?
SuperRedMR2 wrote:I've had a lightened one before, didn't do me any favours and it was missing the harmonic balancer.
Going to stick to the standard crank pulley.
gon wrote:you can(and should) also balance the clutch plate with the engine
Balance it without and then with.
on the second pass
(with) material removal should only take place in the clutch plate
