Hi,
I'm actually studying a 300 bhp engine setup (Or maybe a bit more) and i'd like to know if the stock b-pipe is so restrictive as some users have suggested.
I actually run without cats (2,5" dp + stock jdm b-pipe). I've read that a stock exhaust doesn't have 2,5" pipe size all way long, with the b-pipe being one of the biggest flow restrictors.
May i face a power limiting factor (+/-300 hp at cranck) if i leave the stock b-pipe? I could replace it with a straight 2,5" tube if needed.
Do you know if there's any other flow bottleneck in the stock exhaust system?
Regards
[Mk2] [Turbo] How restrictive a stock exhaust is?
Re: [Mk2] [Turbo] How restrictive a stock exhaust is?
Not sure on the diameter but would think 2.5 or 2.75 all the way through would be fine. Larger is just a waste and noisier at those power levels.
Thanks. I agree with you. In the states eveyone says the b-pipe is very restrictive. It's easy to figure out as the 2nd cat is placed there. But i'm not so sure about how restrictive a jdm b-pipe might be.
Regards
The inlet to the stock muffler is a restriction as well. If you are prepared to open up the stock muffler and replace the factory inlet with a 3" pipe, it really frees it up.
Al-sw20 wrote:The inlet to the stock muffler is a restriction as well. If you are prepared to open up the stock muffler and replace the factory inlet with a 3" pipe, it really frees it up.
It seems doable. I've read a post explaining how a guy in the States did it. I'm not sure about the involved costs. Maybe buying an aftermarket exhaust system results cheaper. I'll ask. Thanks!
