[Mk2] [NA] Headlights don't pop up properly
TheLepresean
Post by TheLepresean »
Hello all, having bit of an issue with my headlights, sometimes I turn the headlight knob all the way around and the headlights don't pop up at all, side lights come on, but no headlights - I have to flash the high beams to get the lights to come up and then they work fine. Any suggestions what might be wrong? It's fine nine times out of ten, it's just the odd time that irritates me. TIA.
Torero
Re: [Mk2] [NA] Headlights don't pop up properly
Post by Torero »
One of 2 things possibly Sean.
Either relays or wiring but as ity affects both it's an idea to look before it gets to where the loom splits to each unit.
Cluster switch is on it's way out so is not connecting on the 10th time.
John.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
TheLepresean
Ah! So how do I go about remedying that?
SonicSW20
Post by SonicSW20 »
Check all of the grounds as well.
markstevieandmads
Post by markstevieandmads »
My first bet would be a sticky relay.
thomp1983
Post by thomp1983 »
Sean i can give john (torero) a known working relay and stalk at jae which you can arrange getting from him
Chris
TheLepresean
Chris, if you would that would be excellent!! Can I give you some money for it? Been meaning to go and see John for a while, driven past his car but never heard it fire up :twisted: would be a great excuse to if he's ok with it! :thumleft:
thomp1983
Post by thomp1983 »
Just put something in a charity pot somewhere mate they'd of only been scrapped.
Torero
Post by Torero »
Hi Sean,
I've got the relay and cluster from Chris so PM me when you want to collect. Evenings after 5pm are probably best. :thumleft:
Return to “Electrical”
