Angpozzuto wrote:rev3gtturbo wrote:All old cars of any make/model will rust eventually. What you do about it depends on what the car is worth to you and how long you want to keep it.
I would guess that most car drivers don't even consider a respray or it costs so much they choose to get a new car or newer car
I have found this out so many times especially with mr2s as young guys buy these cars as cheap thrills but when they realise these cars need time money and tlc then poor old mr2 ends up in scrap. my mr2 is for keeps so I don't mind spending more than I would ever get back so having a good solid shell is worth it to me.
Are there are other rust hotspots I should be checking. I've checked the sills t bar and the corners of the boot is there anyware else I'm missing
Agreed. I have spent more restoring my MR2 from a bar shell than I would ever get back. Here is my build thread:
http://www.imoc.co.uk/forums/viewtopic.php?t=173618
Seeing as my car was a bare shell build, the rust ares were easily identifiable.
These were:
- inner sills
- Boot corners behind rear wheel arch
- T bar edges (Top corner of A-pillar)
- Underneath the T bar plastic trim that the glass panels slot under
- Behind the rear bumper in the corners
All documented on my build thread.
Front wings and rear arches don't generally rust. This is usually a sign of badly repaired damage in the past.
Hope that helps mate.
