[Mk2] [Turbo] ecu
[Mk2] [Turbo] ecu
i have no power to Mailfunction Indicator Lamp and abs checked bulb ok this car has had a starter button fitted wonder if problem may be there what wire do i need to check to see if power is getting there
- Peter Gidden
Re: [Mk2] [Turbo] ecu
12+VE to dash bulbs is fed from ignition switch via the GAUGE fuse.
- Peter Gidden
Re: ecu
hahaman wrote:please make it simple for me to understand all other dash lights work just the 2 as stated,are we talking about fuel gauge fuse
I can't make it any simple than that.
There is a 7.5A fuse called "GAUGE". You'll find it in the footwell fuse box.
- Peter Gidden
Re: eml
hahaman wrote:checked fuse not that
What voltage reading did you get across the fuse with the ignition on?
