Peter Gidden - SBITS wrote:mr2mk2 wrote:Found a secondhand afm for £50, Peter, is it worth trying to clean my existing one first before buying an unknown?
You can try cleaning (again).
I wouldn't be buying an uknown. Buy or borrow one from a trusted source.
Do you know of any trusted sources Peter? I will try taking the top off and cleaning the track. By the way, the CSW is broken now so I've disconnected it but not throwing a fault code. Am I correct in thinking this will only.be an issue with cold starts?
