Hi all,
Having had my 2nd Mr2 turbo for a whole 2 months I'm looking at putting it away for the winter.
Does anyone have any tips. It's a GT so I am concerned about the leather on the seats. I have a solar trickle charger to keep the battery alive and plan on covering everything in WD40.
Storing for winter
Re: Storing for winter
I've just put my tubby back on the road after storing it for 5 years and the only real problem I had was with the ECU that had melting? capacitors
in the ECU.
Even in a dry garage dampness will attack the car so a liberal spraying of wd40 and suchlike will definitely help
I didn't have any problems with the leather seats but my car was kept in a dry garage.
in the ECU.
Maybe you could try that leather shampoo on them before putting it away. Just remember to check your coolant
bigal wrote:I had was with the ECU that had melting? capacitors
in the ECU.
I had this happen with my rev2 ecu (can happen rev1 too i think) (no sure about rev3+) .. the electrolytes seep out of the large capacitors on to the circuit bored and course problems .. ie your cel light on permanently or intermittently , with no codes stored.
Quite a rare problem though .
