shim bank and valve adjustment tool
User avatar
LimeyMk1
Re: shim bank and valve adjustment tool
Post by LimeyMk1 »
The hallowed shim bank is with me now. :mrgreen:
Mavros
Post by Mavros »
Limey,
Can I have dibs on it when you've finished?
cattouchin
Post by cattouchin »
I have a set of shims from an engine I stripped down, i'll stick them in the post to add to the collection if whoever has the shim bank at the moment can PM with an address.
Mavros
Post by Mavros »
I've got the shim bank at the moment but I'm about to send it off to Limey. Probably best if you send yours onto him.
User avatar
LimeyMk1
Post by LimeyMk1 »
Mavros wrote:I've got the shim bank at the moment but I'm about to send it off to Limey. Probably best if you send yours onto him.
Cattouchin sent them to me, all ready to be added to the bank, just got to measure them up to go in the right bags. 8)
Mavros
Post by Mavros »
Can you let me know if you have any of the following: 2.5, 2.55 or 2.6 as I seem to need these more than anything else.
User avatar
LimeyMk1
Post by LimeyMk1 »
Mavros wrote:Can you let me know if you have any of the following: 2.5, 2.55 or 2.6 as I seem to need these more than anything else.
I'll measure them up this evening and let you know. :thumleft: I have an old 3SGE head in the garage still with shims, I'll check to see if they are the same as the 4AGE and measure them up too.
Mavros
Post by Mavros »
Cheers mate,
I did contact my local dealer but they want £10 + VAT for each shim!
User avatar
LimeyMk1
Post by LimeyMk1 »
Mavros wrote:Cheers mate,
Yup, that's about the going rate unfortunately. :(
User avatar
LimeyMk1
Post by LimeyMk1 »
Sorry about the delay, 2.88 is the smallest I have. :(
User avatar
Lauren
Post by Lauren »
I've got a load but they are in Macclesfield. I think some of them are marked up.
Depends where you are, you could pop over to Mark's workshop and have a look.
I won't have time to look myself unfortunately. I thought I might have been down there this weekend working on the AE86, but didn't manage it.
I did ask to see if Mark can bring some home, but he's not sure where they are!
Sorry not much help unless you can pop over there really. If you're not in a rush I can have a look when I next get down there, but it might not be for a few weeks.
I'll ask Mark to have a quick look for them for you.
Mavros
Post by Mavros »
Much appreciated Lauren,
I'll wait for you to check them when you get round there.
JamesDaniel80
Post by JamesDaniel80 »
Hi,
I've been pointed in your direction because I'm in need of some valve shims...
I have a list of the ones I need (there are 14 in total with thicknesses varying between 3mm and 3.3mm).
Who do I need to go to, to make a purchase?
Cheers!
James
elbon50
Post by elbon50 »
JamesDaniel80 wrote:Hi,
Cheers!
James
Suggest you send a PM to LimeyMk1 James :thumleft:
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
User avatar
Lauren
Post by Lauren »
Mark has had a look but there are just the buckets, not the shims I'm afraid. Tom may know where they are.
I will have a look when I'm next down the workshop to work on the AE86, but I'm not sure when that will be. I might get a chance on the bank holiday weekend. I know we have at least three sets of shims in all as Tom got them all, measured them and used the appropriate ones to build my engine.
Polypedates
Post by Polypedates »
Hello, I am after the shim bank and shim adjustment tool if available please? Here's hoping Limey still has it as I am not far from him...
JamesDaniel80
Hi,
I've just sent the hallowed shim bank back to Limey so it should be with you soon.
James
1987 MR2 MK1b
2002 Audi S3 Quatro
User avatar
LimeyMk1
Post by LimeyMk1 »
:thumleft: Cheers James.
mark35
Valve shims
Post by mark35 »
Can anyone help with valve shims.
After 0.118 and 0.123 shims
MaryWard
Post by MaryWard »
That's really helpful. I have plenty of shims & buckets in my basement and I could send them away, since I am not using them. Thanks for sharing!
