Not exactly an electrical issue but......
How do I get the cover off the rear speakers? One of them is fuzzy like there's a loose connection so I want to check it out but I don't want to snap the cover trying to get it off.
MattLG
MK1 Rear speakers
- Lauren
- IMOC Committee
Re: MK1 Rear speakers
Think you have to remove the whole of the rear trim to get to it IIRC
You need to unbolt the seatbelt from the middle of the B pillar, take off the trim panel behind it, then take of the trim panel round the side window, speakers are behind that.
hth
Jimi
hth
Jimi
Black is not a colour ! .... Its the absence of colour
Streuth!! What a cafuffle. I'll check everything else first then I reckon
MattLG
MattLG
Matt, it doesn`t take to long, just a number 2 pillips screwdriver, 14mm spanner and 5 minutes of your time.
