mondeo droplinks fit?
welly_59
Post by welly_59 »
i've got a noisy droplink on my front and i've heard that the 95-99 ford contour droplinks fit. After a bit of research i've found that the ford contour was sold as a ford mondeo over hear.
here's the post i've seen with the droplink information:
http://www.mr2oc.com/showthread.php?t=2 ... =end+links
anyone here able to verify this?
stevenb
Re: mondeo droplinks fit?
Post by stevenb »
The ends may match but you'll probably have to shorten them by cutting and welding back together.
Ebay ones are cheap.
Or Twosrus uk. :wink:
spudgun
Post by spudgun »
All the ford ones I have seen have the threaded bit on the same side, whereas the mk1 has the threaded part at 180 degress to each other.
So it will most likely end up having to be shortened and twisted.
tunna_uk
Post by tunna_uk »
Vauxhall Senator ones are close, I have them fitted to the front of mine, however you have to enlarge the hole in the strut and the role bar because the senator ones have a larger ball joint on them, the trade off is a stronger part. :wink:
tunna_uk
Post by tunna_uk »
Forgot to say as well they are only a tenner each!!!
Does anyone know of any rear links that match?
crazylegs
Post by crazylegs »
as far as i know the ford fiesta/escort mk 5 are the nearest.you have to cut and shorten ,(rotate as needed)to fit.
dex
Post by dex »
Vauxhall Carlton are the closest ones I've found that fit the front, the only modification required is to drill the antiroll bar and strut holes out to 12mm. Pattern parts are nice and cheap for the Carlton.
System-G
Post by System-G »
spudgun wrote:All the ford ones I have seen have the threaded bit on the same side, whereas the mk1 has the threaded part at 180 degress to each other.
I don't understand what you mean... I replaced my front droplinks on friday where the original items and the replacements had the thread on both sides (facing the same way)...???
Photos courtesy of twosrus.co.uk
spudgun
Post by spudgun »
Sorry then G, I must be thinking of the back ones then. I know one of em needs twisting.
System-G
Post by System-G »
Quite possible... can't remember what the rears look like even though I was looking at them on Friday #-o
ldavies83
Post by ldavies83 »
Looks like they are
