This is not always the case.
I replaced mine with a brand new vapour trap when i had similar problems with the windows open
& its made no difference, the more petrol in the tank the less smell i get when the windows are open, the smell is very strong from around the handbrake gaitor which would lead me to believe its a gasket on the top of the tank which is causing the problem.
This is a very common fault which is now begining to affect mk2,s also.
Im going to drop the tank very soon before the bad weather sets in
& see if i can cure it once
& for all, will update with what i find, cheers, Jinxy
