BenF wrote:.... but all credit to MrT, the Mk2 and Roadster don't seem to suffer from warped disks on track.
You're not trying hard enough! =D>
B.
Blokey wrote:BenF wrote:.... but all credit to MrT, the Mk2 and Roadster don't seem to suffer from warped disks on track.
B.
Icsunonove wrote:Ben, I can supply you with templates to get an accurate picture of the warp on the disc if you want. See below:
<snip>
Tom
BenF wrote:Icsunonove wrote:Ben, I can supply you with templates to get an accurate picture of the warp on the disc if you want. See below:
<snip>
Tom
Tom - thanks! I'm tempted to see if I can pick up a dial gauge locally to me this weekend and measure the run-out on the disks that are on the car.
I wrote:Dry fit the brake disc, but don't overtorque the nuts. Just nip it uniformly and check the error has been corrected.
If ok, remove the disc and apply a very thin and uniform smear of copper grease to all the mating surfaces on the disc. Apply a very thin and completely uniform layer of chemical metal to the hub mating face (remember the maximum thickness required should be no more than 0.1mm (or 0.004")).
Fit the disc and gently and diagonally tighten the nuts, checking the runout all the time at the outside edge of the disc. As you tighten the nuts the disc will move. Hopefully if you have applied a really thin and uniform layer of chemical metal the disc should not move much. You should be able to make the very final adjustments to get the discs to run very accurately. Using this method I managed to get both rear discs running to within 0.02mm or 0.001", measured at the very outside edge of the disc. The maximum acceptable runout according to the Haynes manual is 0.15mm or 0.006", so I am well satisfied with the job.
If anyone needs to do this procedure I will provide further details and will supply all the templates shown above.
Hope this helps someone else, Tom
BenF wrote:Blokey wrote:BenF wrote:.... but all credit to MrT, the Mk2 and Roadster don't seem to suffer from warped disks on track.
B.
ROFLOL! That's not what you said at the Nurburgring
B.
...I could repeat it but the Sweary Mary Police might come and get me
...although your language was a little colourful on that occasion too IIRC. Let's turn in to this corner...err...no - it's ok - have another go......errr....ok - no worries - make it the best of three [-o< ...wasn't worried at all
Come along and have some more goes in mid September
B.
