Updateage- Sorted! (with pics) Curing 5th gear pop-out
User avatar
Lauren
Re: Updateage- Sorted! (with pics) Curing 5th gear pop-out
Post by Lauren »
jimi wrote::oops: next question how do I upload the pics :oops: can't sem to find out how to do it
Jimi
Click on 'Album' at the top. then upload pic, then select knowledge base, then browse on your PC for pic.
jimi
Post by jimi »
Pics are up, words on their way.
Jimi
Black is not a colour ! .... Its the absence of colour
BenF
Premium Member
Post by BenF »
If you need a hand with this, PM me.
We did move the static HTML how-to's over, but if they were in the Database they'd have been lost ..
I've just approved all the Pics you've uploaded for the articles, plus Lauren's for the 5th gear pop out problem - some top beardage there Lauren ;)
User avatar
Lauren
Post by Lauren »
BenF wrote:If you need a hand with this, PM me.
Ben, i tried to upload those pics but was met with a load of red Xs so ended up just linking them off my site, which seems to work okay.
Was amazed tbh Ben, just how easy it was to swop that hub and selector fork.
sadako
Post by sadako »
OK, at the moment i'm running without soundproofing while I get around to fitting my 3rd brake light and deciding if i'm going to run any extra cables with the loom before i put the carpet back on. At 70-75mph I get this annoying buzzing sound behind my head that goes away when I push the gearstick forward in 5th. The noise goes away again if I speed up to 80 (testing on private land occifer).
Could this be a prelude to 5th gear popout or is it just the gear cables resonating at that frequncy or something?
User avatar
Lauren
Post by Lauren »
sadako wrote:OK, at the moment i'm running without soundproofing while I get around to fitting my 3rd brake light and deciding if i'm going to run any extra cables with the loom before i put the carpet back on. At 70-75mph I get this annoying buzzing sound behind my head that goes away when I push the gearstick forward in 5th. The noise goes away again if I speed up to 80 (testing on private land occifer).
Its likely the selector fork pushing on the hub or hub pushing against dog teeth.
A precursor to 5th gear popout is that when you lift off the gearstick will 'nod' forwards. 10mm is okay but tells you that 5th gear is on the way. 20mm or so means its going to be sooner rather than later.
ldavies83
Post by ldavies83 »
=D> =D> =D> Well done Lauren, Impressed is an understatement! I dont know how you do it and work out all these fantastic ideas!!
Cixot
Post by Cixot »
Very nice Lauren, pictures make it look 100 X easier than someone trying to explain it.
Now, my Blue T-Bar is popping out of 4th! Is this a similar problem with an easy fix or am I living in hope!?
Icsunonove
Post by Icsunonove »
Oh dear Ryan,
I'm afraid that's a completely different kettle of fish! :(
User avatar
Lauren
Post by Lauren »
SeaSnake wrote:Very nice Lauren, pictures make it look 100 X easier than someone trying to explain it.
Sorting out 4th would involve a hell of a lot of work. Would involve stripping just about everything out to get to it i'm afraid.
5th is easy because its actually outside the main gear casing and is on the end of the input/output shaft.
Cixot
Post by Cixot »
So, living in hope then! :?
Guess I will have to drop the gear box and replace it with one of the many spares i have, just hope I pick a gud'n.
Can those parts you bought for 5th be purchased cheaper anywhere else as I am thinking of buying a few sets and putting them in a couple of these spares ready for anyone who want a complete unit? :salut:
User avatar
Lauren
Post by Lauren »
I doubt you'd be able to get the fork and hub anywhere but toyota tbh. they are not that expensive really. £20 for a fork and £50 for a hub.
