Cant get my NAT type to status:open. Its currently on moderate.
I've followed the steps on youtube and google etc but no luck.
192.168.1.1 wont load but 192.168.0.1 will but then can get past the username and password box! Any ideas guys? I've tried 'admin' as both but they wont have it.
I've tried these links: http://www.youtube.com/watch?v=2rcaUh0bmWM http://www.youtube.com/watch?v=IVIBuwDs ... re=related
Any help would be great.
what modem do u have? if u are with sky the password wont be admin it will be a code on the back of the modem if u are virgin its usually changeme other then that type the router make into google and you should get threads telling u the user/password etc
H3RB wrote:what modem do u have? if u are with sky the password wont be admin it will be a code on the back of the modem if u are virgin its usually changeme other then that type the router make into google and you should get threads telling u the user/password etc
Sorted it mate, just done it, well got into the sky router settings anyway!
Now just gotta in put all the codes from XBL to the sky router!
quicker/easier way, set the static ip on the 360 then in the router set the xbox's ip addy as the default DMZ server
i get this a lot..
reset your router.. then power down for 2 mins.. restart
then go on the xbox and do a check network status...
some times i have had to do this 2wice but has always cleared it..
pistol pete wrote:i get this a lot..
