the reason i ask is im having cooling problems ,,
tha head gasget is all done so no problems there
all it is as im on the road on a longish journey the engine temp rases every time u load the engine more, all it take is the heater to be put on for about 10 secs after u let off and it keeps it cool ,,,
ps mark ed,, it stayed cool until i nailed it from the camara then it got warmer again, so thats why i let u pass
im takeing the fiat rad out tomorrw and will join the pipes togetter to run with out the rad, and try that and see how it works
andi
who has got fiat cinq rad in front of air con and engine one
Re: who has got fiat cinq rad in front of air con and engine one
an update i have removed the 3rd rad from the nose cone and so far no overheting problems,,,
Like you had a choice!!
Brook aka 'Enrico' has a Cinquecento radiator in front of his Toyota rad and aircon I believe...
http://www.imoc.co.uk/forums/profile.ph ... file&u=580
yes mark like i said the temp was getting warmer ,,
and becides im better looking
