| View previous topic :: View next topic |
| Author |
Message |
trunks_mk1
Joined: 14 Apr 2006 Posts: 384 Location: Old Kent Road Feedback Score: 0
1988 Toyota MR2 Mk1b
Posted: Sun Feb 07, 2010 1:54 am Post subject: mr2 mk1 t-bar seals - where can I buy new? |
Apart from twosrus in the states, can these still be purchased in the uk? anybody have any sites which they have brought these from? not sure why but been having a bit more leaking then usual recently. Been reluctant to change these but I think the seals are the main cause. the guides have been changed to the off center ones which helped .
thanks
| Back to top |
MartG Premium Member
Joined: 07 Apr 2005 Posts: 5610 Location: Staining, Blackpool Feedback Score: 4
1986 Toyota MR2 Mk1 SC
Posted: Sun Feb 07, 2010 9:17 am Post subject: |
http://kbox.ca/catalog/product_info.php/cPath/39_64_69/products_id/55
_________________ In 1642 the cold air ballon was invented - it never really took off though.
The only time a man should hug another man is after the death of a family member. Or maybe of a wife if she was particularly good at ironing.
| Back to top |
trunks_mk1
Posted: Sun Feb 07, 2010 3:15 pm Post subject: |
| are these oem or copies? twosrus are selling them for $75 a side.
| Back to top |
Jim-SR Premium Member
Joined: 03 Feb 2007 Posts: 785 Location: Basingstoke Feedback Score: 0
1989 Toyota MR2 Mk1b
Posted: Sun Feb 07, 2010 5:15 pm Post subject: |
youll probably want to change all of the retaining strips underneath them as well at the same time. its near enough guaranteed that the centre one will have no studs left attached to it, and the seals are rarely the issues, its water getting in underneath the retaining strips rather than between glass and seal.
jinxy did a guide on how to solve it. since ive done it (not replaced them, just put new screw clips in there and siliconed everywhere) there is hardly any water getting in. and what water is getting in is coming through the rust behind the windscreen and the t-bar glass side seals. the ancient t-bar seals themselves are faultless. might save you $200+ just to change the screw clips for about £10
| Back to top |
oukie IMOC Organiser
Joined: 28 Sep 2006 Posts: 1648 Location: near oxford Feedback Score: 4
1990 Toyota MR2 Mk1b
Posted: Sun Feb 07, 2010 10:19 pm Post subject: |
I was also going to suggest what Jim-SR did, It does help massivly doing this and no seals were replaced on my mk1
_________________ Mk1b White coupe Jan90, Mk1b Mica blue T-bar Mar90,Mk1b T-bar Mica blue,Aircon,Jan90, Mk1b T-bar Gunmetal grey 88, 4 mk1's
| Back to top |
trunks_mk1
Posted: Sun Feb 07, 2010 10:46 pm Post subject: |
| cool! thats great, hate to be a bother but the search option isn't so greta o this? any one remember the name of the write up that Jinxy did?
| Back to top |
trunks_mk1
Posted: Sun Feb 07, 2010 10:48 pm Post subject: |
also whats the screw clip look like and where can I source this?
| Back to top |
Posted: Sun Feb 07, 2010 11:10 pm Post subject: |
http://www.imoc.co.uk/forums/viewtopic.php?t=71686&highlight=tbar
the parts are...
90189-04029 x 12 (plastic clips)
90189-04110 x 6 (apparently discontinued when i tried to get them. these are the oval plastic clips for the centre retainer, just re-use existing ones and silicone underneath them if you cant get them)
90168-40061 x 18 (screws, if your t-bar leaks then yours might well be rusted)
62373A x 2 (these are the centre panel parts that will almost certainly have sheared their studs off. they are probably crazy expensive or discontinuted though. i just siliconed the crap out of mine to stick them to the roof.
also, there are the same seals and retainers running down the door a-pillar. i also pulled all this apart and sealed it all up. i basically put silicone around all the plastic clips so that water couldnt get past them, then i also siliconed all the retainers to the roof to double up on sealing. i did the same on the a-pillar door seals.
i thought it hadnt worked, so i ripped my headlining out so that i could fault find. and it looks like it did work, but because there is lots of water already in the car, the condensation accumulates on the cold metal/glass on the roof and drips back down giving the impression of a leak still. the only leaks im finding now originate from the sides of the t-bar, which is the seal that is part of the t-bar glass, and doesnt drip on my lap so i dont really care. all in it cost about £20 i think for the clips.
| Back to top |
trunks_mk1
Posted: Sun Feb 07, 2010 11:54 pm Post subject: |
| thanks! just had a quick read...my leaks are mainly from the corners? will that solve it? mines not leaking for the windscreen area.
| Back to top |
Posted: Mon Feb 08, 2010 11:17 am Post subject: |
| depends on whether the leaks are from the roof seals or the glass seals. which corners, inside or outside? if outside then the seal is possibly leaking around where it meets to the door seal part as well. it should fix everything. if not then spend the $200+ on new seals and youve not really wasted any money, just a few hours of your time. chances are new seals alone wont fix it though.
| Back to top |
trunks_mk1
Posted: Mon Feb 08, 2010 2:43 pm Post subject: |
mine are the outside seals....the ones where where the tie rods are. Its weird, depending how I park my car, i.e on a slight hill, backwards or forwards, the amount of leak varies...sometimes never. i can live with it but if fixing it for a 'few quid' is poissible i'll do it otherwise i'll keep the money for the mechanics and car my two towels in the car for overnight rain.
| Back to top |
Posted: Mon Feb 08, 2010 10:32 pm Post subject: |
| trunks_mk1 wrote: | mine are the outside seals....the ones where where the tie rods are. Its weird, depending how I park my car, i.e on a slight hill, backwards or forwards, the amount of leak varies...sometimes never. i can live with it but if fixing it for a 'few quid' is poissible i'll do it otherwise i'll keep the money for the mechanics and car my two towels in the car for overnight rain. ![Smile [Smile]](images/smiles/icon_smile.gif) |
ive tied a rope from the little plastic clip behind the seat with a loop on the end that i hook onto the seat adjuster at the bottom. then i lay a folded tarpaulin over it. any water that drips onto it just runs off the sides, keeping the seat dry. thus far i find maybe 3 or 4 droplets on it a day, even in heavy rain. so its barely even needed, but does its job when it is. i find ice is more of a problem. when we have rain then it freezes over i will drive somewhere, and then the ice thaws out and when i park up it finds its way in (i guess where the roof has flexed around on the drive it opens up the gaps).
| Back to top |
