coolant temp and water temp sender pics
Does anyone have diagram or pics of location of the engine coolant temp sender and the water temp sender in the engine bay please?
Re: coolant temp and water temp sender pics
Stand by the nearside rear wheel, looking into the engine bay.
Find the dizzy cap, look slightly down and to the left
- you'll see a cast elbow that comes out of the engine block
- this is where the coolant exits the engine.
On this, look at the side that faces towards the passenger compartment, there are two connectors.
One has a green
(dark green) latching plug, and brass body
- this is the ECU coolant temp sensor.
The other is smaller and has a spade type connector
- this is the sensor for the dash.
HTH! Ben.
One has a green
HTH! Ben.
